So, my Tohatsu M70B has been sitting up for about a year so I decide I will get her water ready again. Ordered a water pump rebuild kit because the impeller has never been changed and the motor is a 94! Anyway, the first two bolts come out with some force but the other two shear off inside the pumps lower case. So, proceed to drill out the bolts and I promptly drill into the lower unit! These holes are right beside the bolt holes that secure the water pump. My question is, would JB Weld hold up if I used it to repair and re-tap the bolt holes? Also, the drill did some minor damage to the pumps lower case as well. Same thing, will JB Weld hold up? Lots of vibration going on in this area. Any advice would be helpful. Like I said, bonehead of the year!!!
Thanks,
Bob
Thanks,
Bob
