Hello all. My boat is a 16" Lund Renegade with a 1988 Suzuki dt-75 on it. I have only owned it for about 1 year and it has never ran well. Heres what it does..... it starts right up using the choke and will idle ok, when i put it into gear it will either die or idle ok then when i put it into gear and gas it it will bog down and not get the rpms up. If im sitting at idle and use the neutral throttle handle it revs up with no problem. Im not getting any alarms or idiot lights so i have done the odvious and replaced the plugs, fuel filter, drained float bowls, compression are all around 115#. Nothing was dirty or looked that bad. I ran it this weekend at Castlerock lake and it ran good a few times but most of the time it was bogging and smelling like gas. A few times it jumped up and ran like a champ. Thanks Ted
