slredstorm62
- Jul 28, 2009
- 66
i just took my boat out for the first time yesterday, and when i got off the lake i pulled the plug and a little bit of gear oil came out. the whole bottom of the bilge is covered with it./ i looked and found oil on top of the shaft that goes from the engine to the outdrive. but the second time i went out it didnt fill up again and only put in about 4 ounced of fluid if that. should i change this? also, when i left the dock my oil pressure was about 40 and after it warmed up and was runnin WOT i only had 20 lbs is this normal or could my oil sender be messed up. i am thinking about switching to mechanical
