1996 Merc 225 no top end power
pnltbox
We have a 1996 Merc 225 offshore, ran great last year, now will only pull 4600rpm when in gear, in neutral, it will pull 6000, tried new plugs, all filters replaced, 105 - 110 compression in all cylinders, Any ideas what it could be??? Spent a couple of thousand $$ already and no one has fixed it. HELP ME!
Faztbullet
Re: 1996 Merc 225 no top end power
Ignition or fuel problem,have you tested to see if sparking on all cylinders???
pnltbox
Problem solved! Had a Bad stator and # 5 coil was dead:)
