Re: Hooking up hour meter, need run signal
This KOSO hour meter has a internal battery and has only one wire which is the sensing wire.
You are supposed to wrap it around a spark plug wire. The meter will start to operate automatically after you start the engine and record the time after 1 second.
I hooked the sensing wire to the dark green tach signal which it worked but when I shut the engine down and turned power on to the accessories (GPS, lights, bilge & livewell pumps) the meter started to totalize again.
I wonder if I need some type of resister or something in the sensing line to hide the stray voltage
