ok helping out a fellow boater help need please.
mercruiser 1986 5.7 has the thunderbolt old stile box bolt to the riser.
after taking the the engine apart to change head gaskets, hook everything back up but now we cant get any spark, before the season start he had install a new module in the distributor,. boat was starting fine before the work .
he has the boat yard mechanic check the iginition system, he said because he did not ground the black wire from the dist module it kill the module he went on to say the box on the riser is also dead, but the box was grounded, so how come both module just dead like that, kinda fishy. your thought guys.
with the key turn on we got juice on both side of the coil.
