Voltage reading from a '77 'rude 55hp 2cyl2st WOT
glengold
I purchased this boat (97 welcraft 16') with a 97 evinrude 50. My garmin depth finder showed 15-16 volts WOT, of course 12-13 motor off. The lower unit failed on the '97 so I traded for the rebuilt 55hp. However, I'm not getting much (if any) voltage increase WOT! never more than 13 volts. Does this mean i have a bad R/R or Stator? I'm not sure what to expect out of the '77! Do I need to bring it back to the mechanic I bought it from??
jimdd810
Re: Voltage out of a 77 rude 55hp 2cyl2st
i think your voltage is good dont worry and keep boating
glengold
Re: Voltage reading from a '77 'rude 55hp 2cyl2st WOT
obviously just make sure I have a full charge each time... because my bat. died on me last time out...
jimdd810
is it an old battery?
glengold
no but i was told that the old motor could have been frying it w/too much voltage. I never used to worry about it but now I'm watching the voltmeter on my fishfinder like a hawk and get worried when i see it drop below 12
jimdd810
I would first do a load test on your battery then check the stator output.
jtexas
If your battery died on you, then something is way wrong. It should never get down to 12 volts, much less below 12.
Unless maybe you're running a trolling motor on the cranking battery? Or one a those fancy oxygenated bait tanks? Or a huge amp to blast your tunes out over the water?
The FF won't hardly draw enough current to measure, unless it's also a GPS having a hard time locating a satellite.
unregulated charging voltages usually get on up there, 15, 16 or more volts. A high quality marine led-acid battery will handle it. I been using Interstate deepcyles for cranking -- total of 11 years from the last two.
An AGM or gel-cell battery won't tolerate that much charging voltage very well.
If the voltage is higher when the motor's running, then it's charging but it does sound like not enough.
Corrosion/loose connections will drop voltage, so inspect all the wiring coming into and out of the rectifier. Measure voltage at each junction in the circuit from rectifier to battery to rule out a wiring problem.
And as said, get the battery load tested.....a failing battery will drag the voltage down, too.
