A few days ago i was on the river and hit a rock with my johnson and the shear pin did not break. After hitting the rock, the engine locked up and i could no longer pull the recoil. In order to get it to start again i had to turn the flywheel so i could pull the recoil and get it started again. I was able to start the motor again after turning the flywheel however the waterpump stopped working. Not only does the waterpump not work, but the motor will not shift gears properly now, which it did fine before i hit the rock. I took the head and lower unit off to check the imperller for damage and found nothing wrong. Any ideas????
