Older Johnson Outboard
firetac5
I just purchased a '74 Glassmaster with an older 35HP Johnson motor. It runs great, but I cannot find the VIN number in order to register this outboard in Texas (yes, hulls and motors are registered separately here). Can any be kind enough to suggest where I might find the VIN number. The previous owner restored the boat beautifully, bit he painted the whole engine. I would think the VIN would be inside, but I am a novice at this. I suspect the motor may be as old as the boat.
samo_ott
Re: Older Johnson Outboard
If he painted the entire engine he probably painted over the data plate. It should be on the transom mount. Post a picture if you can.
firetac5
Thanks. It was painted over, but was easily cleaned off.
samo_ott
Oh, and welcome to iboats. What year 35 did it turn out to be?
