intake manifold leaking????
777memaw
I replaced the manifold on my mercruiser 350 260 HP 1978 model. Now there is oil on the intake wiped it off and it keeps coming back. This is a edelbrock performer EPS aluminum intake. Anyone seen this B4??? Is not coming from the gasket it appears to be coming through the aluminum just laying on the manifold just below the carb.
cr2k
Re: intake manifold leaking????
Maybe the valve cover gaskets?
John_S
Rest assured that the oil is not passing through the aluminum
Are the vent tubes hooked back up to the flame arrester?
Did you use sealent on the bolts?
777memaw
I did not use sealant on the bolts. Thanks that is probably the issue.
buzzm19
777, I have seen it a million times, on those older motors, you need to put sealent on the two bolts in the center right below the carb on both sides, those four bolts go into the oil valley and oil is coming up through the threads. Buz
