I have a 89 2.3 omc i/o capri 17`. I`m getting an occasional clunk from the stern drive. It starts between 2500-3000 rpm`s. It doesn`t effect the engine or performance. It just clunks, there is no consistency when it happens. You can see the stern drive jerk when it happens
I have taken the stern drive off thinking it might be the U jouints, but there fine. I drained the gear oil, very little filings. New prop. this year.
Putting it in gear, forward and in reverse goes in easy ( stern drive still off )
There is some play between the prop and the upper case U joint shaft, not sure if that is normal.
Any ideas,
Thank you,
Shawn
Any ideas,
Thank you,
Shawn
