Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
1994 DT 40 has 2 issues one under load trim bleeds down. No leaks but bleeds down. Also at full throttle light on bottom right of oil/temp etc gauge comes on. Not sure what alarm even is.
Re: 1994 DT40 Trim bleeds down also alarm @ full throttle
That is strange that it bleeds down with no leaks, maybe you should go one pin up so it doesn't go down too far ...... make sure your oil reservoir is always 75% full ....
One pin UP? It has to be bleeding by the bypass or the piston but not sure how to prove it. The alarm thing bothers me more. Not sure what the alarm is. Where can I buy service mamuals for this motor?
