evinrude 9.9..what year
ewan777
please help me i have an evinrude 9.9 model no.E10BELCA serial no.B023213 can anyone tell me the year as i cant find it anywhere and where i can get an operators manual ? :
Vic.S
Re: evinrude 9.9..what year
No I cannot find that model number either. Usually it is possible to spot a single misread letter but not with this one.
I suggest you check it again very carefully .. using a magnifying lens.
E10BALCE by any chance? That would be 1989 but would expect another suffix letter on the end
ewan777
no vic i have just checked again and thats the right number , made in belgium if that helps ????? any other ideas ?? am lost.
Vic.S
Yes the B indicates that it was made in Belgium.
BE that it is a derated electric start Belgium made model ( BA would be a similar rope start)
L = long shaft
then there should be two letters that indicate the year from the word INTRODUCES C is Ok, that is 8, but that should be followed by another letter from that word ... but there is no A in introduces !
Finally one would expect a suffix letter of no significance.
Might have expected to see another letter between the C and the A.
I have also checked the numbers of commercial models but there is nothing there.
Also look for a disc on the power head with the numbers on. Not always there for some reason.
Are you located in the UK or RoI by any chance?
the machinist
OK I will be making some assumptions here.
As the 9.9s were only made from 1974 to 2007. With your motor being E10BELCA The first letter E = Evinrude, -- 10hp (rounded out = 9.9) -- B for Belgium, -- E = electric start.
Now there is not a letter 'L" in INTRODUCES code which would designate the first of the year code. However there is "U" = 7, C = 8 & E = 9 which would cover the years your motor was manufactured. This code started in 1979. So it it is not possible to be a 1979 because your second year code is "8" so unlikely it is a crappy marked C, so therefore the logic is it would be crappy "E" missing the upper ears, making the motor possibly a 1998.
Vic.S
The machinists theory is good. But cannot find E10BEECA listed either !
Crucial though is whether or not that is an "L" or a badly stamped "E"
Is the motor a long shaft model?
If it is then the "L" is an "L" for long shaft!
If it is not a long shaft model then the "L" may well be a badly stamped "E"
Have to ask I suppose. It is a 2 stroke not a 4 stroke ?
ewan777
hi i have cleaned the plate up and the no. is E10BALCRA any ideas ?
ewan777
please clarify . what does ohm it out mean i am a novice help
Vic.S
Yes CR are the date letters for 1984 C = 8 and R = 4
I knew you'd got it wrong! Thats why I told you to check it carefully! :mad:
"When in doubt, Ohm it out." is just his signature.
ewan777
thanx a lot guys as you probably gather i will be asking quite a few questions and its nice to know that you lot are out there n thanx again
ewan777
Re: evinrude 9.9.throttle cable .
hi guys am back . any idea where i can get a throttle cable for 1984 evinrude 9.9 outboard , online ?
Vic.S
Oh dear according to the parts diagrams a 1984 9.9 does not have a cable operated throttle!
It sounds as though your Belgium built model may have the same system as the 8 hp models or more likely the system fitted to N American models from 1986 onwards.
take a look at the parts diagrams at http://shop2.evinrude.com/Index.aspx?s1=ca167a06da6bc6e5660b1a11cba6e517&catalog_id=0&siteid=1
Maybe you can figure it out but I think you will have to have chat with your dealer!
ewan777
so do you think i might be able to get a kit to fit ? or is it curtains ?
Vic.S
Look at the two alternatives I have suggested in the parts catalog.
Try to figure out which, if either, of these is likely to be the right one, but then talk to a dealer of your choice quoting the model number They will be able to help you I am sure.
