Re: 1962 sea king SIXTY
The Gale shares most mechanicals with the Evinrude/Johnson motrs of similar years.
60 hp Gale production covered 60,61,62 and 63.61 on up have fixed high speed jets,
58 though 63 share carbs with 58-60 have adjustable high speed jets.The plug wires are screwed into the distributor cap.61-67 models are equipped with either a belt driven magneto or a similar belt driven battery ignition distributor.
Often thought of as heavy motors at about 200 lbs they are 40lbs lighter than todays 2 cylinder Evinrude Etec 50.
They are extremely thirsty and waste a lot a fuel as many did back then.
Maximum rpm is 5,000. 24:1 fuel mix on 63 motors.You might check with the experts at
www.aomci.org if the 63 60 hp Gale motors can be run on 50:1
