I have a 1989 Johnson 150 (J150STLCEM) with no spark.
flywheel appears to be bad. P/N is 583844 but I cannot find one.
Does anyone know if this is a 9 amp or 35 amp system, and if there is a replacement flywheel with a different p/N I can use ?
Cant really go by that chart it is not correct on the V-6 crossflow(ask TD) you magnet locations for that flywheel are: with keyway @12 ths magent slit will be @ 6 and 11
