1972 Johnson Outboard goes forward in reverse
rumads
I figured out why my boat wouldn't start. The safey switch had fallen out of its spot. I opened up the handle part (excuse my terminology not a mechanic) and found that the safety switch was faulty and had fell out so when the handle was going forward and backward it was not going in neutral so I thought. I put that back into the little hole that it fits in and put the unit back and the key turned over the motor. I then took it back out to the lake and dropped the boat in the water and put the boat in reverse only to notice that it went forward. When I put it in forward the engine would rev up but wouldn't move. I thought that perhaps I had put the handle together wrong. Since this was not a big issue I pulled the handle in reverse and the boat went forward. Once I got out in the middle of the water I put the boat in forward and the motor kicked a little and it went forward so I then tried reverse and it still went forward. What could be the issue? Thanks.
jay_merrill
Re: 1972 Johnson Outboard goes forward in reverse
How could we possibly answer this, without knowing which 1972 Johnson you have?
F_R
We can't. But just reading between the lines, I suspect he has a Hydro-Electric and the shift switch has fallen apart. He is calling it a safety switch, which it is, but it is also the shift switch. Breaking or falling apart is an all-to-common thing.
The only cure is a new switch. Get out the $$$$
jay_merrill
And plan on spending a lot of time looking for one!
