Hello all.
I have searched all through the forum for this but I'm only able to pick up bits and pieces and have tried a few methods.
I have a GameFisher 3.0 (Tanaka TOB-300). I bought it new and really rarely used it. I then had it stored in my garage for several years. I decided to use it again this year. I went to this forum and found Tanaka's site and downloaded the PDF on how to take it apart and such. I took the carb apart and cleaned it real good. It was gummed up some. I took apart the main jet, Jet Needle, cleaned the seat needle. then started it up in a drum of water and everything worked ok. I took it to the lake and it worked fine but would die on me after a while, but it would start right back up. I did see this same issue on the forum.
However it's been a month and I went to take it out again and the darn thing wont start. When it did start it only started for a minute or so then died. I've been screwed ever since. I took it all apart again, cleaned it, replaced the fuel lines from a local hardware store. Still wont start. It acts like it wants to, but never really gets going. Now I did notice something interesting. The bowl where the fuel comes doesn't always look full. I made sure everything was open as well as the screw on the gas tank. Could it be the float seeing it is so old, or the new fuel lines? They are slightly larger than the original.
John
John
