Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Ok so the rings are broken on #4 cylinder,no scars yet just small nicks on head, is it possible to replace piston without removing power head from lower unit?
65 psi compression 120/ 118/120 rest 1/2/3.
Thanks I was afraid of that,It,s been a while since I had her apart,the memory banks are a little slow thees days.
looks like a new piston Rings and a gasket set,
Also is the piston rod pressed in or c clips?
