Re: 90 hp Chrysler Outboard
If it is running well and looks good too, you MIGHT be able to get 700-1000 from someone who needs to repower and wants a Chrysler. You might be able to get this over at The Chrysler Crew, Chrysler marine website. In reality, that will almost never happen. You would be lucky to get 500.
If you part it out, the lower unit, tilt/trim (if it has one and if it is working), ignition, carbs, block, and flywheel will fetch more than the running engine. Props are getting scarce for that 2 piece lower unit and the prop alone--again, if it is in good condition should fetch about 50 bucks. Distributor, if it is electronic also is a pricey item.
