The motor runs at a high idle. It runs at 2500rpm. When I back it down, it kills. I have checked the fuel flow and it is good. I Tried new gas, new plugs and stills idle rough. This motor is fuel injected
Contaminated carbs my friend. Unfortunately you should take this one to a Merc shop. Even if you clean the carbs yourself, you will need a special vacuum tool to set the motor up correctly.
