Can anyone tell me the proper way to test the fuel pump on a 25 hp Johnson? I have removed the output line and it is pumping fuel but I don't know what is considered the correct amount. My main problem being that the motor bogs after 1/2 throttle when under load. Works great in a barrel both in and out of gear. I suspect my problem may be a coil breaking down(one is severely cracked), and have order replacements but thought I might check the pump while waiting for parts to arrive. Thanks for all responses.
