I have a 1997 Mercuriser 3.0 Alpha. It ran for about 10 minutes, long enough to get me from the launching ramp almost to my cottage dock. Then it died.
After paddling to my dock, I replaced the distribuer cap and condenser, then it started right up. Then, after about 10 seconds, it died. Then I cleaned the contact point at the top of the coil, reconected the ignition cable and it started again... then died after about 10 seconds... now I can't get it to start at all.
It turns over really well, but no spark.
I replaced the plugs and and ignition wires, but it still won't start, or spark.
I bench tested the ignition coil and it produces a spark through the spark plug when I ground the coil. However, with the coil on the engine, when I turn the key and attach a plug to the coil, there is no spark.
I have been told that this model of Mercuiser doesn't have points, so apparently that can't be the issue.
Does anyone have any advice?
