Re: engine/transmission problem
a spun hub in the prop might very well work with no load. same with the engine coupler. did the boat heat up when you were in the water? if so its the coupler. if it pumped water and ran cool but no gears its the hub in the prop. you might put it in gear and see if you can turn engine by turning prop backwards. a sure test is to put it in water and see if it runs cool while slipping. You might need to try to plane to get it to break lose again. some times they will reset for a while.
