Correct exhaust shutters??
Ringerd
While trying to run down an overheating problem I discovered that one of my engines didn't have exhaust shutters and it wasn't the one overheating.
Took the serial number of the 1994 engine (OF115xxx, V-6 LX, 4B carbs) to the dealer. They "special ordered", so no can return, a pair of # 807166A3.
Guess what, they don't fit, wrong style. From looking at the pictures in the service manual, I have the "later style".
Both engines have the same type Y pipes on them. Not a hole for the shutters but a slot and a grommet in the square hole at the bottom of it.
Looking at parts for different years and later serial numbers of the same engines I find parts numbers of 807166A1 and 807166A2 on other models.
Any way of telling what the correct part number is for the shutters I need?
If it helps, it is a 2 piece manifold as the 1994 diagrams show.
achris
More fish than mountain goat
Re: Correct exhaust shutters??
For an original 1994 exhaust system that is the right number. If you have the slots in the top of the Y-pipe, then you have a 1996 y-pipe and the part # is -807166A2.
Chris.......
Ringerd
achris,
Thanks for the response.
Can you tell me the difference between the 807166A2 and 807166A1?
mercruiserparts.com is showing the 807166A1 for a 1996 thru 1998.
Is there someplace else to look up parts and/or cross reference?
achris
A2 used with one piece manifold and A1 used with 2 piece manifold. (I suspect they are actually the same)....
Ringerd
Mine has the 2 piece manifold so I guess A1 is the one I need.
Thanks again.
