Thanks for the reply,White wire on the engine terminal board is tachometer signal. At the dashboard switch hook the white wire to the signal terminal on the tach, if it not long enough, attach it to an "M" terminal and run a jumper wire to the tach signal terminal. run a red power wire from the "I" terminal; od the ignition switch to the power or 12 volt terminal on the tach, and run a black ground the a common ground under the dash.
