I recently acquired a boat I've been working on. I was told it was about a 1980, 120hp Merc. I believe the serial number is 2364043.
It had been sitting for 7 years, so needed some R&R. Did some maintenance to the engine and got it running. When I went to test out the trim, I was able to get it to trim all the way up, but when I go to trim down, it only goes down about a 1/4 of what it should. From Center to Center on the cylinders bolts I can only get it to go down to 24".
Just wondering what my plan of attack should be? I was thinking of changing the oil and trying that. Then disconnect the cylinders from the leg and seeing if I can get them to move without the weight of the leg.
Any suggestions would be greatly appreciated, thx.
