Gromulin
 - Jul 5, 2010
 - 230
I've been following CL for about 3 months now. I keep noticing something: whenever I see a boat that advertises "new motor, only 10 hours!" it always seems to be a Merc 4.3 that had been replaced. Almost all the boats are between 2000 and 2005. Have not seen any 5.0 or 5.7 with similar stories..at least not advertised. They all seem to be cosmetically well kept, look like new and otherwise in good shape.
So I guess my choices for speculating are:
1- The ones I've seen are usually 18-19 footers, typical first-boat. No upkeep by rookie boaters? 25 year olds with HELOCS..rode hard, put up wet, blowed up early? Dude...check out this gauge...it's TOTALLY redlined, dude! Awesome!
2- Something makes the 4.3 more prone to gettin blowed up than the 5.0 or 5.7. Bad cooling system? More prone to overheating? (I'm also guessing that overheating is the most likely to cause a low hour motor to need a total replacement)
3- My completely unscientific and subjective survey is just that...BS..(hey, it worked for the Global Warming guys!) I just happened to only notice blowed up 4.3's in my price range (under 16K, 2000 or newer). If I was searching in a higher price range, I might see more 5.0 / 5.7 with similar stories.
Thoughts? Opinions? Wild *** guesses?
