Re: 1960 Johnson flywheel
Are you using the harmonic balancer puller with the (3) 1/4 -20 bolts?
If you are then pull harder, then tap on the center of the puller to try to get it to pop.
If you are using another type of puller, please quit or you'll break or ruin the flywheel.
