I can shift into forward and reverse without any problems. Everytime I shift back into neutral the motor dies instantly. I just crank the motor back up and shift back into gear and its fine.
Ive adjusted the lower shift cable, checked reverse lockout, checked the lower shift cable for binding, checked the shift cutout switch, etc... Nothing works. I finally noticed my upper shift cable (from shifter to transom plate) has about 1/4 inch of "play"... which lead me to start looking into the actual shifter as the problem.
Does anyone know where I can find a manual for a Quicksilver 883710A02 shifter?
Reference the post below... Looks like another member had a similar problem as I am having.
http://forums.iboats.com/showthread.php?t=415673
