3.0 Mercruiser Issue
chap1984
Have 1984 3.0 mercruiser with alpha one outdrive. Just rebuilt engine,rebuilt carb..My problem is...when in water under a load the engine runs fine at 1000 to 1700 rpm.when i start to acc.engine tries to bog out and die. Playing with the acc..sometimes i can get 2000 to 3000 rpm's....but the engine gets rough and smooth back and fourth. When i trailer the boat with muffs on the engine runs fine...of course its not under a load...but could anyone offer any advice??? Much thanks.
fat fanny
Re: 3.0 Mercruiser Issue
Beforw what alpheus said replace the fuel filters on pump and in the fuel line inlet to carb try it again check fuel pressure and if that doen't help rebuild carb? Good luck
