Hello-
I noticed my water not spraying out of the peehole on my Merc. I tried to hook up a hose directly to the peehole on the motor to push out any blockage, to no avail. I did notice that water did NOT even come out of the lower unit intake when I had this hooked up. And I also tried to hook up the earmuffs to see if I could force water through. In both instances, water slowly drips out of either the intake (when hose is connected to peehole), and out the peehole (when Earmuffs are connected to lower unit.
So my question is, if it was an issue with the impeller, would water come out of the lower unit intake? I am trying to determine if I have a blockage or need to replace the impeller blade.
Also, does anyone have any tricks/tips to clear out a blockage from the hoses?
Thanks, Mark.
Thanks, Mark.
