lncoop
- Apr 18, 2010
- 5,147
I have a 2002 90 horse two stroke Merc on my party barge. The last couple of times out (week or so between trips) she's smoked quite a bit at initial start up. Once she's warm the smoking stops and doesn't reoccur for the rest of the day, weekend, etc. I'm not having any performance issues and she's not at all hard to start. In case it matters, for various reasons the motor has been tilted all the way up to the point that oil has spilled out of the reservoir a couple of times in days prior to the smoky startups. Is it possible the smoke is the result of the spilled oil burning off? Also, if it helps, here's my starting method. Before turning the key I disengage the shifter (push the button) and run the throttle to wide open a couple of times, each time leaving it open a few seconds, then I bring it back to idle and turn the key while pushing in. I read somewhere (on here I think) that was the way to do it. Thoughts?
