RobbyA
- Jun 5, 2010
- 306
I have hit a bit of a snag on my restore. I have drilled the rub rail and separated the transom. Going to pull the cap and the floor seems to be glued to the sub-floor. The cap and floor are all one piece of fiberglass. Here are the choices I see that I have.
A. Try wedging the floor as pressure is applied to a lift system with chisels and pry bars.
B. Cut the fiberglass floor around the edge and try to salvage it and put it back together with the cap.
C. Cut the floor, when the cap is replaced, fiberglass a new floor on top of the sub-floor.
D. Do something that a pro on here suggest.
E. Use five gallons of diesel and a match on it.
All advise is very much appreciated!!!!
