Re: 6 hp evinrude running rich at high speed
I have not tried testing the float in that matter, gonna try that next. I installed 2 new brown packing rings and inlet valve clip/seat/needle. Packing nut is tight, but I can still turn the needle. I put a new sierra fuel pump on it and new fuel lines and bulb from the tank all the way to the carb. I had to rotate the new fuel pump cover/screen to get the hose in the proper place. Maybe I boogered up the fuel pump when I did that. I need to locate a schematic for the pump, and reassemble it as it came out the box. Is it possible to assemble the fuel pump incorrectly and make it pump so much gas the float can't regulate it?
