Simoniz
- Dec 30, 2007
- 251
Re: Mystery to be solved - reward to whoever gets it!
Correct me if Im wrong but isnt the fact that you have solid water flow out of the relief port on one side of the drive and not the other a bit of a red herring?
After the water has run through the manifolds and risers, doesn't it then go into the y pipe where the streams are rejoined before then exhausting into the drive where it then has the choice to exit via the left relief port, right relief port or the prop?
