1967 evinrude 6hp no power at wot
macgyver 08
ok so i got a 1967 evinrude 6hp fishermen for $50 rebuilt the carb noticed on the intake that that one of the studs for the carberator was stripped (by previous owner then tried to epoxy the stud in) so i replaced the manifold and gasket. the motor runs and idles fine and throttles up in nuetral but when put in gear its like it has no power tested it on a 1436 jon and only got 5mph been thinkin it through and checking everything even checked the compression wich was less then 30psi on both cylinders which tells me that the rings are gone? any way to get a engine rebuild kit for this motor i have tried looking with no luck any sugestions would be great
thanks
Jon
samo_ott
Re: 1967 evinrude 6hp no power at wot
30#'s a side is toast. Should be 70-80#'s or so minimum. It could be a head gasket, I had one go on my 5.5 before (same block). Or you could try a decarb. I'd pull the head off and see what things look like inside.
Oh, and welcome to the forum :)
macgyver 08
i pulled the head the rings and pistons look good i guess but not really sure what they should look like and the cylinder walls look good and smooth the head gasket is in tact but a lil brittle. the pistons as well as the head had alot of carbon build up on them and i cleaned it all off with some sea foam
change the head gasket throw her all back together and call it the day? or go ahead and change the rings as well while i got it tore apart?
Rscardina
id do the head gasket first and try some seafoam or with a bottle spary some mix in each cylider...i would then re-check compression, if its better then you saved yourself the work if not you may have to dig deeper
also, how many pulls did you do?..you may have to give her a few good strong pulls
macgyver 08
i turned the motor with a wrench i didnt pull it would that affect the reading?
macgyver 08
well now i feel like an idiot so now i dont really know if i had good or bad compression and i tore the motor all the way down *face palm* and one of the rings broke on me after i removed one of the pistons.
heres my question now is this motor worth spending the money on new rings since one broke a head gasket and so on? or should i just part it out?
Daviet
I guess if it were mine I would fix it up. But I really like those motors.
macgyver 08
i would like the fact of having an old motor that runs strong but is $250 total in the motor worth it?
Daviet
That's a question only you can ansewer, as for me, the ansewer would be yes.
samo_ott
Crap, you already took it apart right down to the pistons. That was fast. I think a set of rings is $60-70 or so, but I'm not sure as I never buy em. It's up to you if you put it back together or not. A good running 6hp will fetch $350-$400 in my neck of the woods.
macgyver 08
ya ive tor down all kinds of motors doesnt take me long this was my first ourboard though as it sits right now im not in alot of money so im just gonna part it out and be on the hunt for another motor like a mid 70s johnson 9.9 i think it will serve me better but any ways thanks for the help and if anybody needs any parts contact me and heres a list of what is good
flywheel
coil packs and ignition assemply
head
crank
cylinder head
intake
carb
pull rope assembly
lower unit
exhaust housing
tiller arm
transom clamp
engine cover
anythign but the pistons and rings i buggered them up too much i believe
make an offer and ill see what i can do for ya
