40 hp 1971 evinrude ski twin carb float adjustment
boatero
Runs great.
Was out with friend the other day....he didnt put the gas tank on correctly, unfortunately i didnt check this and pulled the carb off.
I got a carb kit. I bought a manual and sent it to the wrong address. So no i am sitting here with the carbs cleaned and taken apart and I need to know what the spec is for the float adjustment.
Any info on adjusting these correctly would be appreciated.
thanks
boatero
Re: 40 hp 1971 evinrude ski twin carb float adjustment
never mind....the float adjustment came with the carb kit. :) now i have a sputter/backfire at idle problem
Daviet
Did you start with the low speed jet out 1 1/2 turns?
boatero
I dinked around with it i started at about 1 turn out then 1/4 turns after that. seemed to get better for a time.....but not comfortable success.
The slow idle screw has numbers 1-5 on the knob.
What do you suggest in setting it?
Thanks
Daviet
Forget the numbers on the knob, adjust the needle valve to where it idles the best and turn it out another 1/8th turn. Install the knob with #3 at the center of the adjustment.
boatero
figured it out! jimminy!
i left a bolt out of the starter mount assembly, it was blowing smoke....also put the re-seated the slow idle needle nice and tight, now it runs in a good low idle...
Good deal!
Oh I backed the adjustment screw out about 1 and 3/4 turns.
boatero
thanks Daviet, I will do that.
