Hi Everone I hope someone can help at my end ropes here it goes OK I have a 1990 90 HP mercury outboard the tilt& trim was working but when I came in yesterday to put in on the trailer could not get the engine to come up It been working fine all season anyway as I came in I was trying to lift the motor when it was going on the trailer while trottleing couldn't get it on the trailer right so I back up in reverse and went back out turn around and went back on the trailer but just then the tilt &trim did not work but then I tryed it again after playing with the shift (trottle ) it came up slow. Anyway got it home and try it again and it worked then all of a sudden it went down and stop will not come up as I hit the Buttom for the tilt&trim all I hear is a clicking sound so I pulled the cowl off and the noise was coming from the solenoid. Now I know there is 3 of them one for the started and the other 2 for the tilt&trim I am asumeing. The clicking was coming from one of them could not tell they both were clicking now I thought it was the upper on so I replace it And still nothing my first question is since they are both clicking do I have to replace both of them would 2 go bad. or Now I am asumeing again could it be the wire down to the motor to the tilt&trim. or the tilt& trim motor it self. But it seems like there is no juice getting to the motor the 2 solenoids just click when I hit the switch to bring it up. I check the battery I put a full charge on it so I know thats good engine turn over fine nothing wrong with that. Like I said I had it working for a few times when I got it home but then it went down and stayed down now all I get is clicking from the soleniods. Please Help also someone told me to get the engine up i can unscrew the plug that hold the fluid and pick up the engine manually. Again anyone out there Please help answer on here also if like to email me at [Thank you again sorry for so long of a question Ed
