how long?
rebuild25
Do I have between sanding the old paint to bare aluminum and hitting it with the primer? It's been about 2 weeks and will probably go to a third. Do I just hit it with a little scotchbrite before primer if it has sat too long. Seems i read somewhere to not wait too long between these to processes.
Woodonglass
Re: how long?
Scotch Brite Pad, Acetone, Tack Cloth, then Self Etching Primer.
I'm Just Sayin...:D
6meter
Re: how long?
On alot of paints you can't wait long between the primer and base coat.
vegasphotoman
Re: how long?
once you got the whole boat primed sand it with 320 wet and clean/tack paint
Kiwifisher
Re: how long?
The recommended time between removing the oxidation layer (sanding) on aluminum and hitting it with primer is about 20 to 30 MINUTES. :eek: As we all know, this however is not really practical in the real world, so do as Woodonglass said. Just make sure everything is set-up ready and waiting before you start the scotch brite
