Re: Carb base gasket replacement
Ok, so I replaced the base gasket on the weekend. WHAT A DIFFRENCE!!!
Took it to the lake let it warm up, put it in gear, and went to adjust the idle fuel mixture screws.
I set the idle screw for about 800 rpm, then started adjustment.
I was 2.5 turns out to begin with, but for some reason and I think the linkage
IE, the spring.
Is not tight enough to pull the carb partially closed at idle.
and had a heck of a time trying and failing to set the jets.
Any words of wisdom???
THX
Rob
