grandpaking
- Aug 25, 2010
- 7
I have a 1994 Mercruiser Alpha One, V6, 4 Barrel, 4.3L, 262 CID, Gen II, Serial # 0F281678. I am not getting spark to the plugs. We get spark out of the coil but not out of the distributor. With the help of a local Mercruiser dealer, Southern Marine, and a local "expert tech" we have run all the tests (several times) called, "Troubleshooting Thunderbolt IV Ignition System." We have replaced the coil, distributor cap, rotor assembly, and sensor assembly (twice). All the experts say it can't be the ignition module, but no one is willing to bet the price of one to see if it might be! Can we remove the module and bench test it with a high degree of accuracy? If, yes, tell us how. If, no, tell us what else we can do to find the problem and fix it? I will appreciate any help you can give us. Mercruiser has refused to help. Bob
