Why not just glass ,fair, and paint ...
No rule says ya gotta have a cap ..
Unless you just want one for looks or something ...
I also finished building the last two circuits for the meter panel.
I usually use a hole saw, I bet a forstner would take a while!
If I might offer a small mod/option to your low batt circuit?
As designed(left bottom), the low batt indicator LED will be dimming/fading out linearly (See LED current, ID2) as B+ begins to drop due to the LED is being driven with a constant voltage source(B+). This is possibly not desirable especially at different viewing times/conditions .
This can be improved (small mod) upon by driving the LED with a constant current source config(Ic-Q1)... (right top/bottom). As seen, the LED will stay same brightness and run at a constant lit level from around 12V-3V (Notice LED current, upper right, ID2) over the same range until it blinks out at around 3V.
Just a thought to consider gm,
Yeah the low fuel is a moot point, saw that but, the low batt LED's intensity deviation over some/a range caught my eye. Yes, probably be a darn weak battery before it'll dim out, was thinking maybe in the sun or something you'd maybe want/need it as bright as it runs at 12V when it was, say at like 10'ish V...
Was thinking, approx down 2 mils @ 10V from 8 mils @ 12V, ya loose 1/4 of the intensity, not sure if that was too much or not, depending of course.
Like the addition of the integrated lights, super cool gm!
Wanna now make'umm blink on and off at progressively high rates and intensity's as they approach critical levels??? :lol: Could code you up a 8 pin SOIC micro that'll do it all and then some![]()
Holy smokes GM , I would be pulling what’s left of my hair out trying to figure out all that circuitry !
:hail: You certainly have the knack for it !
Have a splash date set yet? Fantastic work as always.
