gm280
- Jun 26, 2011
- 14,605
Well today the temps AND humidity have lowered some and I took advantage of it too. Temps are 89 degrees and humidity is 43%. So I still sweat but was also able to do some work as well. :rockon:
I decided it was time I welded up the parts for that second stretcher/shrinker unit since I had most all of it cut out, drilled
, and ready to be welded. I started off using the TIG welder, but after fighting the welding settings for a time, I switched to the MIG welder and got things done. I realize I honestly need to practice with the TIG, but if you get the amperage setting set too high, you melt right through the metals instead of welding them. And my abilities of setting everything up correctly is still iffy on a good day. We won't even talk about aluminum right now... :facepalm:
I welded everything but the main body and post parts. I have those parts ready to weld on, but decided to wait until the final 3/8" plate comes in.
And that brings me to that silly story...again!
I honestly didn't know how hard it would be to get two little pieces of 6" x 6" x 3/8" plates HO steel in to make this project. The original order was shipped via FedX and I tracked it until it got to Indianapolis, IN and it never left there again to get to my house. :noidea: Even after two weeks...
The metal company stated they would reship them again. Well I finally got the second order yesterday. Problem is, they only shipped one of the plates and not two. :doh:
So now I wait for the second plate to arrive to finish that project.
op2: :clock:
Life is so amazing that you can't get angry, you just have to laugh and wonder how things ever get done with all the ups and downs constantly going on in the world. :tickled_pink:
