1985 Bayliner Capri Cuddy Cabin Engine
Status
Not open for further replies.
rsc
I recently bought a 1985 Bayliner 1950 Capri Cuddy Cabin. The person I bought it from didnt have an owners manual but told me that the engine was a volvo 2.1 liter. The engine is a volvo engine but someone else told me that bayliner used a 2.3 liter engine after 1983. I cannot find anything in the engine compartment that would tell me what size it so I thought maybe someone on this board would know. <br />Thanks Randy
JasonB
Re: 1985 Bayliner Capri Cuddy Cabin Engine
A friend has an 85 bliner and it has the Volvo 2.1 AQ125B. I rebuilt the carb last night for him. If the drive is volvo, it is likely the 2.1L. If the drive is OMC, it may be a 2.3 Ford engine.
rsc
Thanks Jason. It is a volvo outdrive. Maybe I will be able to get a few parts for it now.
JasonB
It is a fairly easy engine to work on. It is the same base engine as a Volvo B21. I think I was told it was used in the 240 series of cars? Gust be careful to get marine grade parts. Your local NAPA parts store can order Sierra parts for it. You also may want to pick up a repair manual for it. I am looking at the Clymer, which I am usually happy with, but wonder if the Seloc wouldn't be better for this engine. You may be able to find many of the parts you need here at IBoats. Otherwise, you may want to check out ebasicpower.com or boatfix.com. You also may want to look up Sierra Marine Parts on the internet and see if they will seng you their dealer catalog of parts. They sent me one for the asking and it was invaluable in getting the correct parts for both my Mercruiser and the Volvo I am helping ot with.
Dunaruna
Volvo used both 2.1L & 2.3L in their boats. They are essentially the same block but with different internals - I can give you details if you want.<br /><br />In automotive language, the 2.1L was a B21 and the 2.3L was B23. These numbers will be at the beginning of the engine number stamped on the block.<br /><br />Aldo
rsc
Do you know the location of this stamp? The only numbers I could find on the engine were on a metal tag by the starter, but it started with neither B21 or B23. I must be looking in the wrong area. Thanks again
bobspub
would you happen to know what the timing and points should be set at on that engine?
Robj
What did the metal tag say? I believe the B21 or B23 are the block casting nos. There are different engine set-ups that used the B21 or B23 blocks. Post the numbers from that tag and we should be able to determine what engine you have.
Have a great day,
Rob.
Mn Warrior
HI RSC, is there a round sticker on the valve cover? I had one of these and the sticker was black from age and heat but if you look at it from an angle you may be able to read it. It should start with an AQ. I have a clymer volvo stern drive shop manual 1968-1993 that helped me out a lot with my Bayliner Capri.
rhettw
I have a 2.3 vovlvo I just tuned up tonight.
SAme boat as Mine
1985 bayliner with cuddy (capri)
omc 270 sterndrive
vovlo 2.3 4 cilynder
firing order 1342
point gap .018
timing I think is either 20 or 30 BTDC
solex single downdraft carb (can be pain in ***!!!!!:D)
Make sure exhaust bellow in back of exhaust manifold is not leaking it causes problems as I found out
jerryjerry05
Timing is 10`BTDC Points set at 18-19 Volvo manuals are available they are so much better than Clymer or Seloc.Jerry
Fishermark
This post has a life of its own - like the energizer bunny - it started in 2004 and keeps going and going...
images
chiefalen
Thats why i didn't post, thought the master would have locked it already.
Status
