- Apr 17, 2002
- 71,373
Re: Aluminum Boat repair - Rivets?
Ayuh,....
My .090 well Bent motor mounts are Pop Riveted into my tin hull...3/16" Pop Rivets,...
No Problems at something over 800hrs, restraining alittle over 200 Horses...
Boater's are generally a pretty resourceful bunch,....
More apt to build a tool, than worry about Not having 1.....
You do not need fancy equipment to pull 3/16 blind rivets. I have pulled well over 2500 of those on a 20 dollar home depot pop riveter. They aren't exactly weak either. I used them to completely rebuild the deck structure and hatches and all in an aluminum bass boat once, and they will hold a heavy load just fine. I am not talking about holding the sheet onto the structure, but building the structure with these.
Ayuh,....
