ConnieMarie
- Apr 29, 2014
- 44
I'm having trouble starting my engine, I typically run the boat once a week. Beginning of season she was firing right up, each week it has become harder and harder to start. Now the engine will not start. It sounds likes its turning over and occasionally it will start run rough for a couple minutes and stall. Last week it ran rough until it warmed up awhile then would start every time. This past weekend wouldnât even start.
The battery is brand new and holds charger about 12.5 volts. The spark plugs are brand-new Tr5 NGK, however I did not gap these, was under the impression they came pre gapped. New plug wires replaced as well. I can visually see gas dripping into top of carb, I've been taking the filter off to allow more air to get into the system at start up. When replacing the plugs today they had what appeared to smell and look like gas on them. I've done some research and ordered a "ignition tune up" kit which includes distributor cap, rotor, condenser and contact points. I have checked all the fuses all seem to be in good shape.
Unfortunately, the boat is already in the water and about a 30 minute drive from home. I intend on bringing up my multi meter to hopefully further diagnosis the issue. The previous owner replaced the distributer cap and some point. I have not taken it off so I have no idea whatâs going on underneath. Iâm hoping I can replace points and condenser without having to adjust the timing, from what Iâve read this will not be possible. Any input would be much appreciated. Iâm a first time boat owner and somewhat mechanically inclined. I don't have a tachometer or timing light hopefully I can find some cheap ones somewhere?
