chevymaher
- Mar 29, 2017
- 2,937
Well if it will make you better. I laid on a tarp in the mud under the boat. Washed and waxed the underside up to the rub rails and the did the trailer. Yes I waxed the trailer to.
I greased the bearing buddies on my axles. Greased the outdrive. Waxed the outdrive. Put the prop on and waxed it to.
There that should bring your fever down a couple degrees buddy.
