MIKESCHWARTZ
- Jun 5, 2005
- 8
Ive recently purchased an 2002 Tahoe Q5 with a 5.0 litre mercury mercruiser w/Alfa1 outdrive.I get an audible beep when coming on plane or sometimes letting off the gas quickly.But not every time. The engine temp is at 185 Degrees and oil pressure is at 40-45 psi idle. Cold it tends to be closer to 60 psi and when go WOT it will go 59-58 psi. I cant determine really whats causing the audible beep. Ive looked at the wireing and grounds but this is the first I/O ive owned. I been a auto mechanic for 10yrs but im lost on this one. My question is What is considered to high of oil pressure for the 5.0? The boat has around 55 hrs on it and has been serviced well.<br />I was under the impression the audible sounder was for too high or too low of oil press.<br />Any help or ideas would be great...
