FreeBeeTony
- May 15, 2002
- 3,992
I don't know what else it can be.........<br /><br />Here is what I have done so far:<br />1) replaced plugs, cap and rotor<br />2) Set timing to 8* BTDC<br />3) Rebuilt Carb.<br />4) Checked for exhaust blockage, found nothing<br />5) Verified correct prop, 15" Pitch<br /><br />I can get up to ~3200RPM, engine sounds great.<br />Tonight I thought it was fixed, sounded as if the secondaries were opening (sounded kinda throaty), then it started to bog down when I tried to give it more throttle.<br /><br />Is it possible the timing isn't advancing properly up at these RPM's? It's the Thunderbolt IV Ignition. Can it be a thermal problem with the ignition module?<br /><br />I received the manual today and am going to go through it tonight.....<br /><br />I could really use some help here.........<br /><br />Any thoughts would be appreciated.
