Engine is a 1985 Mercruiser 5.0l (305) 200hp with less than 200 total hours on it. <br /><br />It has not been in much use over the last few years and was winterized 5 years ago and just brough back into service this year.<br /><br />When the boat is on the trailer the trim/tilt mechanism works fine, but once in the water it begins to "act up". Like after being on plane then slowing back down the trim/tilt does not wan to work. It takes several minutes of fiddling with the switches before they will work again.<br /><br />I have checked all of the connections and wires leading to the trim cylinder, they all appear to tbe okay and the oil level in the cyl. is at spec.<br />ANY IDEAS? This one is quite annoying and really spoiling an otherwise good boat.
